e006-0002 imagepress C1 every morning
Re: e006-0002 imagepress C1 every morning
hello all I have the problem that every morning when the customer turns on the machine shows the E006-0002 code then the client would turn off and on the machine and it will not leave the code. this happens every day. turn on the second attempt always every day then it will not leave until the next day. any suggestions, contacts look fine fuser
Replace or check the Drawer Harness Assembly #1 (FM2-7256-000), this connector is located on the lower left side of the rear frame.
check if All thermistors are working correctly in DISPLAY>ANALOG.
The screw that secures the arm release FL2-2796-000 can loosen causing poor engagement of the fixing/feeder assembly. Make certain that the screw is tight and that the arm release is not deformed.
also check---------
or Replacing the Fixing Heater Cable Unit (Fixing Connector on the Fixing Assembly) FM2-2620-000 and AC Driver Cable (Fixing Connector on the frame side) FM2-2627-000 can resolve the issue.**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
bellir2001
Hi
On the Imagepress C1, I need to replace the following:
FM2-2627-000 - AC DRIVER CABLE ASS'Y
and possibly the FM2-2620 Fixing Heater Cable Unit
I'm having trouble removing the part from the back of the machine. Not sure whether I need to remove the board on the left in order to access the right top side (facing the back of the machine). There are a bunch of boards in there does anyone have a guide on how to remove all those parts? I want to be as careful as possible.
Hi
Fixing Heater Cable Unit/ see doc/ may help
Fix Heater Cable Unit.doc
believe u need to remove the AC driver Box/ Leakage Breaker
for cable/ may be wrong thought
AC DRIVER_Leakage Breaker.doc
AC DRIVER PCB REMOVAL.pdf ----better view**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
