E020 0491 ON IRADV 5035
  • Van Steal
    • 177
    Hi All,
    have this problem with bk dev, there's very little tone left in it( copies v light then you get this code). I'm not familiar with with this range but i checked the toner bottle and that the dev was turning. I've ordered a new dev but not sure if there is a fault with toner being added. Has anyone had problems with hopper units drive clutchs/motors or the like that could cause this? Would be greatfull for any tips.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5009
    Re: E020 0491 ON IRADV 5035
    Do you have upgraded last dcon.
    • CanonSco
      Man About Town
      • Jul 2010
      • 368
      Most common issue with those devs is the drive coupling on the dev side ( black cross shaped coupling held on with an integrated "clip" ) to crack or split or the clip to fail causing it to spin sometimes.
      They are now replaced with one with a pin through it ( although it looks no more substantial than the original item )
      Apart from that, any I have replaced have been for PCQ issues.
      Yes, I am a nerd.
      Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
      • Van Steal
        • 177
        Thanks for the tips guys. I'll go back with a sortware update and dev unit. I'll let you know if its something else.
        • CanonSco
          Man About Town
          • Jul 2010
          • 368
          Great. Let us know either way
          Yes, I am a nerd.
          • Van Steal
            • 177
            Just a quick update, will be going back in the new year will let you know then.
            • CanonSco
              Man About Town
              • Jul 2010
              • 368
              Thanks, good luck with it
              Yes, I am a nerd.
              • KL568
                _
                • Feb 2011
                • 324
                Your Customer is pretty accommodating, if it mine region, they will go ape & start throwing anything they lay hands on it.
                The other thing to check would be modification on the main body (the part that connect the dev 's drive coupling). The original drive coupling is black with just plastic clip; then came material that was so-called strengthen at cross area but still clip; last was what you see, white with pin in it.
                • Van Steal
                  • 177
                  We gave them a spare printer as part was out of stock. Thanks will check that when I get in.
                  • Van Steal
                    • 177
                    Relaced the black dev ass'y. Printer working fine now. Thanks for your advise>
                    • CanonSco
                      Man About Town
                      • Jul 2010
                      • 368
                      Cool.
                      Was the coupling broken?
                      Yes, I am a nerd.
                      • Van Steal
                        • 177
                        Cool.
                        No, the dev uint looked perfect from what I could see
                        • CanonSco
                          Man About Town
                          • Jul 2010
                          • 368
                          Cheers for the update anyway mate.
                          Yes, I am a nerd.
