Just installed a c5051 What are some common Errors that we are seeing on the c5000
  • Simons
    • Jun 2008
    • 490
    New machine c5051 a couple months ago so it should have all the updates. What errors should I review or issues to worry about. I know all about the fixing unit noises. ITB upgrades. Developer drive was fixed on these big ones or soon after launch right?
    Anything else? Oh and what about the internal finisher. Isnt there some glitchy crap or hardware problems with those?
  • Simons
    • Jun 2008
    • 490
    Re: Just installed a c5051 What are some common Errors that we are seeing on the c5
    42 views and nothing worth discussion? Really?
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      If you are familiar with ITB and fixing problems,you have nothing to worry about.
      internal finisher issues:
      E532-0002 error due to the stapler coming off
      jam 1101 issue
      E532-0001
      corner bend of paper due to lower curl of paper
      1400 jam attributed to the left inner cover
      • MrB
        • Nov 2009
        • 147
        Watch out for E0075's
        Could be a number of problems
        I have had a few of these where the ITB has traveled to the rear or the front of the ITB asm,
        There a few things you can do, like after realigning the belt to lift or lower the driver motor (depending on which way the belt has gone)
        Also Ive had a couple of times where the ITB tension holder snaps and this will loose tension on one side of the tension holder (Thus the belts moves across again)
        • Simons
          • Jun 2008
          • 490
          Thanks I would like to know the part number for the tension holder you mean. For sure want to order some of those to be ready. When a e0075 happens isnt it just time to rebuild the ITB? I havent yet taken apart one in the field but have taken one apart and learned the system.
          • zoraldinho
            • Mar 2008
            • 5015
            Measure against intermediate transfer belt full displacement error (E075).pdf
            • MrB
              • Nov 2009
              • 147
              May find this helpful
              • Simons
                • Jun 2008
                • 490
                Ok itb covered. On new machines that have been delivered recent we shouldnt have to worry about weak parts. What else?
                  Not really issues just a few things I picked up the other day.
                  Measures against jam (010A, 020A, FF0A, 010C, 020C) due to the fault in the jam detect sensors PS39, PS40
                  irac9000-038.pdf
                  Side image missing due to soiled polygon mirror
                  <Cause>
                  If the product is installed in the environment where fine dust of less than 1 micrometer in diameter is suspended
                  irac9000-035.pdf
                  In case anyone needs it-
                  Gripper Unit Kit for Inner Finisher-A1 Replacement Procedure
                  ft1-0519-010.pdf
                  Ignore the file names irac9000 etc that's the way Canon Europe decide to name things
