IRC 2550i (New) unable to print color
  • icopier
    • Apr 2011
    • 45
    [Misc] IRC 2550i (New) unable to print color
    Just got hold of a IRC2550i, (old stock,brand new machine).
    However, no CMY at all. when to service mode, seems normal.
    Below is a test page printed out.
    Pls note it is a brand new machine. I am not sure if Canon did any settings or is there any information i need to key in to "activate" the colour drums or laser?
    Appreciate all expert advice and i have attached the printer calibration printout.
    Regards!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: IRC 2550i (New) unable to print color
    What seems normal in service mode?Do you have print test PG-10 color or bW??
    • icopier
      • Apr 2011
      • 45
      Originally posted by zoraldinho
      What seems normal in service mode.Do you have print test PG-10 color or bW.
      I missed that out. Machine is in warehouse right now.
      Should there be no colour, what could be the error?
      If there is, what could be the error?
      I will get a pg-10 next 2 days and update.
      My boss wants me to make sure the machine is working before bringing it back.
      Thanks all expert for the advice.
      • charm5496
        • 2387
        Regards!
        make sure your shutters are open all the way on your laser unit. They tend to stick and block the laser light causing the issue you are seeing and it does not cause an error since the BD mirror is still getting signal.
        We have removed the shutters in some cases, but reseating the drum/ITB housing has fixed the issue in some cases after riding on the truck.
        • teckat
          • 16083
          Regards!
          That is a PG10 Print out ????????????
          • icopier
            • Apr 2011
            • 45
            Nope. that's a calibration test from my IT guys.
            Attached the PG-10. Shutter all checked but still no color coming out from this color machine.
            • teckat
              • 16083
              run a 30 page copy to see if error pops up---
              open right door-cheat the switch-power up- see if patches are on ITB
              1.- what happens when u try to copy a color doc off the glass (error ?/limited function message/can not select full color)
              2.- have u inspected the color units ?
              3.- who set this printer up ?
              see these settings---
              • mramlawi
                • Jul 2011
                • 838
                what the hell !!!! try to make remove the drums and make sure theres no seal on it. check them all check the laser if there;s some screw must remove or shutter !!
                Distinguished road makes you jewel in rough
                • charm5496
                  • 2387
                  I would do as teckat mentioned and run with the door open or run the auto gradation adjust. If you are not getting color on the belt then you have a transfer issue or development problem.
                  if the colors are showing up on the belt then something is up with the system causing you issues when copying and printing.
                  Have you tried flashing the firmware and doing an overwrite all?
                  • blazebusiness
                    SanDiegoCopierRepair.com
                    • 1257
                    Regards!
                    A long shot....Problem with Transfer belt cleaning blade assy? Probably not as this would almost surely give blank copies.
                    • mapsanji
                      • 12
                      I have the same problem but on a IRC3170, B/W is fine but colour is blank, no colour on ITB.....turn m/c off/on and first page is perfect but the rest is printed without colour..?? I hate these F#@king models..( Firmware is up-to-date )
                      ANY IDEAS......someone..!!
                      • teckat
                        • 16083
                        HVT
                        have u tried to clear DC-CON in the service mode and reload System Software
                        (don't forget to print out P PRINT settings first)
