I was up in the lens area trying to solve a Error 733 and 732 error code. After reseating all the cables I and getting almost blank copies from the glass the prined shots look fine so the print engine is ok
So I rechecked the flat connector cables and ended up with an E225. This was due to the glass not being in place on power on.
I fixed that and thought the machine was back up. However, all copies coming off the glass or doc feeder are significantly light. All printer material (laser) are fine. So the print engine is good.
I made sure everything was back in place and did a CCD adjust. I get OK. It sets itself to 1125 when door specs are 1222. Light copy is produced. So I set it to 1222 and cps are darker but still blasted away. I do a trianglulated sky shot and can see the skyshot and a BIG dark A I wrote on the test sheet but everything else is blown away by the light being to bright.
When I do SCANLAMP test= start-ok!
CCD test start-ok!
I went to SVClv2 and not a lot there for CCD other than the 1222 setting and two ref values.
I rechecked all ribbon cables and they all look fine.
Copier works as a printer but copying is out. Even with the AE taken off and manual exposure maxed out dark.
Any thoughts?
CCD test start-ok!
Any thoughts?
