Dev unit Similarity
  • V-P
    • Apr 2011
    • 679
    Dev unit Similarity
    I am short on Dev unit for iR2018. But I have a unit for iR2016.
    My guess is that they are 99% the same.
    Anyone switched with success between the two types ?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: Dev unit Similarity
    100 % the same.
    • V-P
      • Apr 2011
      • 679
      huh - thnx Z !
      • zoraldinho
        • Mar 2008
        • 5018
        Originally posted by V-P
        huh - thnx Z !
        • sal
          • Dec 2011
          • 19
          they are the same
          • V-P
            • Apr 2011
            • 679
            Field Result:
            They are not 100 same. You need to cut out some plastic part from the 2016 series to fit in the 2018 series.
            • zoraldinho
              • Mar 2008
              • 5018
              Field Result:
              Are you talking about developer unit or drum unit??
              • V-P
                • Apr 2011
                • 679
                always Dev unit
                • zoraldinho
                  • Mar 2008
                  • 5018
                  My bad dude, because i believe in part catalog.FM3-3671-000 is number for 2016,2018,2020.In practice is little bit different.
                  • mramlawi
                    • Jul 2011
                    • 838
                    The Same
                    Distinguished road makes you jewel in rough
                    • ernesto
                      • Oct 2011
                      • 430
                      Field Result:
                      absolutly, the ir 2016 developer unit is working ok in the ir 2018, but the cover FC6-4144-000 GUIDE, TONER BOTTLE is diferent , you have to cut out......
                      all the best
                        [ATTACH=CONFIG]13445[/ATTACH]
                        Like the tshirt
                        where do I buy one ?
                        • arielcanon
                          • Mar 2012
                          • 106
                          iR2016 = iR2020 and ir2018 = ir2022. you will not close bottle cover correctly.
                          Learning never ends..
                          Never give up, where there is a wheel there is a way..
                          • ernesto
                            • Oct 2011
                            • 430
                            cover toner bottle ir 2016 cut out
                            • zoraldinho
                              • Mar 2008
                              • 5018
                              Originally posted by skynet
                              Like the tshirt
