C1 print defect
  • Alessandro72
    • Jul 2009
    • 31
    C1 print defect
    I attach a scan of a print made ​​with my imagePRESS C1.
    As you can see there are 3 lines.
    What could be the problem?
    Thanks for your precious help.
    Alessandro
    https://t.me/pump_upp
  • mark921
    • Dec 2010
    • 110
    Re: C1 print defect
    Make sure the dust proof glass is clean.
    Check the the drum for score lines.
    Also stop the copy before it hits the fuser. If its clean, its probably fuser related.
      Re: C1 print defect
      Could a broken pre transfer corona cause this? see Screwtapes post here
      New pre trans imagePRESS C1/C1+
      • teckat
        • 16083
        Re: C1 print defect
        Alessandro
        is that a paper feed image ??
        are all colors exhibiting the problem ??
        did you inspect the developer mag rollers ??
        post a PG10 & some PG5's of separate colors-
        a white line running from lead edge to trail edge on all four colors on prints and copies>
        Check the shutter to the salt sensor and the patch reading sensor.
        • HELIO240
          • Jan 2011
          • 137
          Re: C1 print defect
          Alessandro
          Make an MP5 for each color and a 10 pg. Note the occurrence of the defect.
          Check and replace the primary corona grid of the primary corona wire, check the ITB, check the status of the external transfer roller. Sometimes it may happen that the grid and be dirty primary corona wire or corona and cause failures of any kind. But for better verification of the defect you should post impressions in five PG and PG10 for each color.
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5015
            Re: C1 print defect
            Last year thread
