Canon IR9070 ~ Booklet Printing
  • Smiley27
    • Apr 2011
    • 160
    I dont know if I am in correct place for problem like this, but anyways, this is software related.
    I used to print booklet, but after changeing driver, it doesnt work in same way..
    In section 1 sided/2 sided/bookled, i select bookled but it resets to 1 sided after returning to that window,so i guess driver is broken...
    any suggestions? or other driver?
    • 23010
    Re: Canon IR9070 ~ Booklet Printing
    Is your driver configured to show that there is a booklet folder installed? Could you be selecting a conflicting combination of features, such as zoom and booklet folding? Some of the more recent Kyocera drivers gray out conflicting actions and pop-up an explanation of why these features cannot be used together. I like that. =^..^=
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5018
      Usually is confliting cobination like to havy paper for folding,stiching etc...What tipe of new driver do you have installed?To be shore skip the driver and try the same settings directly on copier.
      • vigour
        • Aug 2010
        • 1038
        here is a workaround until you figure your driver out:
        send the job to the mailbox, as single sided letter copies
        then change settings from mailbox (2 sided, paper size , booklet or saddle stitch etc) to achieve your goal.
        • Smiley27
          • Apr 2011
          • 160
          Alright,lets go easyer way,Ill post dialogue box window,and if you could just set it up for me in your way,cos I think its my mistake...
          I got A4 , 9950~ doc file,I want to make booklet on A3, saddled,with 16 pages on each group,(4 a3 papers=16 a4),hope you understand
          • vigour
            • Aug 2010
            • 1038
            Select Saddle stitch instead of booklet, and it should prompt you to select double sided at some point.
            I think that will achieve your goal.
            I have to do this by trial and error, because I never remember which one does the job , then I keepondering why they have the other choice.
            • Smiley27
              • Apr 2011
              • 160
              But I cant select saddle stich without selecting booklet :S
              • zoraldinho
                • Mar 2008
                • 5018
                On this model definitely need PS driver.
                • vigour
                  • Aug 2010
                  • 1038
                  1 what kind of output do you get when you make your selection
                  2 what driver were you using before
                  3 how did you select before you upgraded.
                  4 why not go back to your old driver,
                  5 you have to experiment, it will take you less time than waiting for us to respond. i have very few people doing booklet, and i have to experiment each time i need to help them then i forget or they change the driver.
                  6 try selecting saddle-stitch along with booklet since you cannot do it alone.
