Canon ir5570 E0014
  • hamdyyassin
    • 84
    Canon ir5570 E0014
    I haev e0014 in my copier ir5570 .
    I replace the heater motor , the dc controllrer and cheak all connectors.
    please i need help,thanks.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: Canon ir5570 E0014
    Check if you can smoothly turn rollers by hand.Probably just need to repair fix assy.
    • charm5496
      • 2387
      I agree. Did you pull the fuser apart and inspect the rollers, bearings and shutter assembly. What shape are the gears in?
      • teckat
        • 16083
        Check front door interlock switch (SW2)>>>>check harness & switch magnet adjustment.
        Lower Fuser roller bearings are XG9-0636-000.
        • COPIERTEC ASSOCIATES
          • Aug 2011
          • 279
          Charm and Teckat are spot on. Had similar problem and changed lower press roller bearings and problem solved.
          • costd
            • Jan 2008
            • 409
            Your milage may vary - even with the new bearings and following the TP, some units still had the same issue. Canon then released a pressure roller unit that had bearings pre-installed (FM2-4683). For us, that has resolved the issue of early bearing wearout.
            • vigour
              • Aug 2010
              • 1038
              Look for a cracked gear.
              • charm5496
                • 2387
                yes the roller with the bearings pressed on has been very effective
