ImagePress C1 Error Code 061-009
+ More Options
Posts
  • ricardobres
    • 147
    Hi Guys
    I have a ImagePress C1 with this error code 061-009. I replaced the drum, 4 developing and 1 developing assembly. I checked and changed with other machine, the hv pcb assembly and I checked the connectors too. Any Idea?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: ImagePress C1 Error Code 061-009
    http://www.copytechnet.com/forums/ca...20-0220-a.html
    • ricardobres
      • 147
      Diferent problem....
      • zoraldinho
        • Mar 2008
        • 5007
        Really????
        • ricardobres
          • 147
          Really...and what can I do to solve 061-009?
          • butitsmyfirstday
            • Feb 2011
            • 60
            Have you checked the connection to the potential Sensor PCB?
            • teckat
              • 16083
              Originally posted by ricardobres
              Hi Guys
              E061
              At time of potential control, a specific level of potential is missing. Or the limiter goes on.
              0009= At Potential Control, VL potential indicates the specified value or more.
              Check your Primary C & that Grid Plate
              make sure that the wire is properly sitting on the little wire blocks on each end of the unit.
              Based on Vd, VL and target contrast potential found with the drum surface potential control, determine the grid bias and the DC developing bias.
              Try & Clear the error first and then run a full auto gradation.
              It is possible that an auto gradation could start while the error code exists. Therefore it is important to immediately perform the error clear as soon as the ready display comes up.
              • ricardobres
                • 147
                Hi, sure for the time, but today I come back to machine.....I replaced thu drum unit, the pcb's, the potencial drum sensor, DC controller, hvps, charge corona, but the code persist. There are other idea?
                • teckat
                  • 16083
                  Have u inspected the cables >especially the potential sensor cable ( easily becomes damaged )
                  What is wall voltage readings>> Net to Hot/Hot to GD/GD to Net ??
                  Did u di this procedure
                  Follow the procedure below to replace the photosensitive drum.
                  1) Turn on the main power switch.
                  2) Select the following items in the Service Mode
                  and then hit OK.
                  3) Run the service mode for drum replacement mode
                  enforcement execution (COPIER > FUNCTION >
                  DCP > DRM-RSET).
                  4) Run automatic gradation correction (full
                  correction).
                  a last resort is>
                  MN-CON RAM clear for the SRAM board of the main controller PCB
                  Operation method
                  1) Select this item and press the OK key.
                  2) Turn OFF/ON the main power.
                  - The RAM data is cleared after the main power switch is turned OFF/ON.
                  - When this mode is executed, all the data in the SRAM board is initialized.
                  The file control information for a hard disk is also initialized, and image data in the hard disk
                  cannot be read.
                  Before you execute this mode, be sure to inform a user that all images in the
                  box are going to be initialized and receive prior approval from him/her.
                  1) Print out the service mode data by COPIER > FUNCTION > MISC-P > P-PRINT.
                  2) Select this item and press the OK key. The machine is automatically activated and displays
                  a message indicating "please turn on the main power again".
                  3) Turn OFF/ON the main power.
                  • ricardobres
                    • 147
                    Thanks, I'll try it on monday.
