Repeat image in Canon iR 3225
  • datamax.systems@gmail.com
    • Apr 2011
    • 17
    [CQ] Repeat image in Canon iR 3225
    Dear friends ,
    sample attached..
    I am facing CQ problem in one of Canon iR 3225. Image is getting printed repeat in both direction X & Y . this is happening in copying , printing and in self print also.replaced drum unit, upgraded systems software but of no use. anybody has faced such problem ..pls help. m/c is 6 lacs old.This problem is happening in once in 10-20 copies/prints. some time it is overlaping printing like same image is printing on twice in a single cycle...need help
  • charm5496
    • 2387
    Re: Repeat image in Canon iR 3225
    probably a laser issue
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5014
      • zoraldinho
        • Mar 2008
        • 5014
        I agree.To good repeating for drum ghost or fix issue.
          • Apr 2011
          • 17
          do i need to replace unit or can be repaired?
          • charm5496
            • 2387
            you can crack it open and take a look but if the motor is off or the shaft is not spinning correctly you will be fighting the same issue again.
            • ps/pcl
              TECH SPECIALIST
              • Jun 2008
              • 35
              Main COntroller Board failure
                • Apr 2011
                • 17
                hi , ps/pcl
                are you 100% sure about main controlller..as the cost of board is almost 50 % of the main machine.i have ask for laser scanner assu.
                • Dayzo25000
                  Hello, got same problem on a 3225, did the new laser unit solved the problem ? Unfortunatly it's different from a 2270/2870 so i'll have to order one, but i'd like to be sure that it's the right part that cause the problem, if not i'll try to order main controller.
                  Regards
