error code e840
  • hf.3h2a
    • Dec 2011
    • 2
    [Error Code] error code e840
    any body can help me for error code for canon ir5570 e840
  • Rachid.Akli
    • Oct 2011
    • 595
    Re: error code e840
    You have an issue with the fixing shutter position detection.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Re: error code e840
      - Check the connection of the connector of the
      shutter motor and the shutter HP sensor.
      - check the mounting of the pin used to match the
      shutter gear phase of the fixing unit (See
      descriptions under "Points to Note When
      Mounting the Fixing Roller.")
      - Replace the shutter HP sensor and the shutter
      motor.
      ir6570-003.pdf
      • Chameleon
        • Nov 2011
        • 200
        Re: error code e840
        I got in the habit of testing the shutter before putting the upper fuser assy back in and again after installed. Make sure it moves smoothly from one extreme to the other. I've seen where it will move ok while removed but installed and under pressure it was binding up. The shutter does need replaced every so often, they tend to wear in the middle and get warped. Also, make sure it isn't in backwards.
        The chance that higher life forms might have emerged in this way is comparable to the chance that a tornado sweeping through a junkyard might assemble a Boeing 747 from the materials therein. -Fred Hoyle
