any body can help me for error code for canon ir5570 e840
error code e840
Tags: None
Re: error code e840
You have an issue with the fixing shutter position detection."Find a job you love and you’ll never have to work a day in your life." Nagy's father -
Re: error code e840
- Check the connection of the connector of the
shutter motor and the shutter HP sensor.
- check the mounting of the pin used to match the
shutter gear phase of the fixing unit (See
descriptions under "Points to Note When
Mounting the Fixing Roller.")
- Replace the shutter HP sensor and the shutter
motor.
ir6570-003.pdfLast edited by zoraldinho; 01-02-2012, 03:15 PM.If it ain't broke, don't fix it
A picture is worth a thousand wordsComment
Re: error code e840
I got in the habit of testing the shutter before putting the upper fuser assy back in and again after installed. Make sure it moves smoothly from one extreme to the other. I've seen where it will move ok while removed but installed and under pressure it was binding up. The shutter does need replaced every so often, they tend to wear in the middle and get warped. Also, make sure it isn't in backwards.The chance that higher life forms might have emerged in this way is comparable to the chance that a tornado sweeping through a junkyard might assemble a Boeing 747 from the materials therein. -Fred HoyleComment
