Sir iam using canon ir 3300 . When we use adf for making copies the paper usually jams r it tells paper jam remove the paper. But ther is no paper inside the adf. I dont know how to solve the problem. Is this problem with adf. what is the solutions? the local service technicians saye to replace the total top of the machine with a new one
Paper jams in ir 3300 adf
Re: Paper jams in ir 3300 adf
Sir iam using canon ir 3300 . When we use adf for making copies the paper usually jams r it tells paper jam remove the paper. But ther is no paper inside the adf. I dont know how to solve the problem. Is this problem with adf. what is the solutions? the local service technicians saye to replace the total top of the machine with a new oneLast edited by blazebusiness; 01-03-2012, 06:25 PM.sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
let your technician check the jam Code , and dessamble the Feeder covers and blow it by the blower looks some of sensors is dusty .
Are You Sure that you have a technician its not easy to change the ADF let him fix well,not everything to change he must think and analyze to solve problems .
regardsDistinguished road makes you jewel in roughComment
Sir iam using canon ir 3300 . When we use adf for making copies the paper usually jams r it tells paper jam remove the paper. But ther is no paper inside the adf. I dont know how to solve the problem. Is this problem with adf. what is the solutions? the local service technicians saye to replace the total top of the machine with a new oneComment
Thanks all for your reply and ideas to solve the problem. I had removed all the parts from the adf cover and then cleaned and reinstalled. But not working. I dont know how to remove the bottom area of adf(black color). Is ther any link or videos which may be helfful for me to do this work?Comment
Mostly the separation pad easily flat and sometimes melted become sticky. Check for the jam code at service mode and refer to service manual where it jam then u need to clean up around those jam area. When it jam without paper mostly sensors failure or it covered by dust, you need to blow it or sometimes the small guide broken until you really need to take a close lookComment
