wave paper on GP 335
  • salah
    • Aug 2025
    my canon GP 335 made wave pages after the passage on the fixing systems,
    if the copy style is on R/V the page block before entering the fixing systems for the second passage, cause of the waves.
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Re: wave paper on GP 335
    If you are describing a curl in the paper after fixing which makes it jam when refeeding thru machine for a second pass (duplexing)..inspect fuser for flat spots on lower roller & check nip width. If what you are describing is a lot or wavy wrinkles that occur as paper leaves the machine your problem will be in the exit door assembly. Wrinkled/wavy copies coming out of the ir 330 / Gp 335 mean the exit rollers need replacement. Very common problem on this model.
    • salah
      thanks, i ll try.
      • charm5496
        • 2387
        Originally posted by blazebusiness
        If you are describing a curl in the paper after fixing which makes it jam when refeeding thru machine for a second pass (duplexing)..inspect fuser for flat spots on lower roller & check nip width. If what you are describing is a lot or wavy wrinkles that occur as paper leaves the machine your problem will be in the exit door assembly. Wrinkled copies coming out of the ir 330 / Gp 335 mean the exit rollers need replacement. Very common problem on this model.
        couldn't have described this solution any better!!!
        • blazebusiness
          • 1257
          Thanks for the encouragement my friend.....appreciate the compliment and have really enjoyed and learned a lot from your posts also!
          • mramlawi
            • Jul 2011
            • 838
            some times Paper Wet make the problem so trouble shoot your problem at one side is there any Paper wrinkled ?
            Distinguished road makes you jewel in rough
            • salah
              at one side every think is normal.
              except some curl or waves at lhe end of the paper
              but when duplexin the curl at the end of the page stop the paper to enter on the fixing system
              • mramlawi
                • Jul 2011
                • 838
                Change the Paper bring a new package of Paper and try it
                • Hopper
                  • Jul 2008
                  • 173
                  Three rollers total and I want to say the part number of one ends in 19 or 29.
                  • sweet.persona
                    Engineer
                    • Nov 2009
                    • 414
                    waves in the paper on GP 335!!!!!!!!!!!!!!
                    Hi every body,
                    i have a problem with canon gp335.
                    the copier made wave pages,when the paper pass from the fixing unite,
                    i have changed the fixing roller, pressure roller,and another things but that does nothing
                    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
                    DAMENE ABDEL AZIZ
                    DJELFA
                    • Brian8506
                      • 1665
                      Delivery rollers on the door. I usually change all 3 though the outermost roller may still be good. FB4-2901/2902/2903
                      • Hopper
                        • Jul 2008
                        • 173
                        Re: waves in the paper on GP 335!!!!!!!!!!!!!!
                        Originally posted by sweet.persona
                        Hi every body,
                        as the picture shows--------[ATTACH=CONFIG]14663[/ATTACH][ATTACH=CONFIG]14664[/ATTACH]
                        Look at my post above. The are three silver rollers with rubber wheels on it spaced evenly. They are in the door assemble and all need replacing.
