ir7095 alignment
  • jiongpao
    • May 2009
    • 413
    ir7095 alignment
    Ir 7095 machine when we print 1 side from adf theres no problem with the image but once we do double side from adf the image slide down approximate in 1cm. I got no idea is it the problem coming out from adf or duplex unit?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: ir7095 alignment
    No idea is it the problem coming out from adf or duplex unit? Are you a tech?
    Go to service mode and check with PG test print,2 side.
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1257
      You could also start by making a 2 sided copy from the glass to see if the adf is the source of the problem. If 2 sided copies from the glass are ok then clean all Adf sensors. Then try adf duplex copies again to see if any improvement. Do not do any sensor adjustments (Sens-Int) for the Doc feeder until you have cleaned all the sensors.
      • jiongpao
        • May 2009
        • 413
        ok will do so once i back to work tomorrow. Will give feedback as soon as possible
        • jiongpao
          • May 2009
          • 413
          Hi, actually it happen only when using adf. Using glass to make 2sided theres no problem. But today it seems no problem with adf. But i scared it may come back again.
          • blazebusiness
            • 1257
            As stated previously, If it only happens using the adf , and if your intermittant problem persists...................Clean the sensors in the adf. Then do SensInit in service mode. Good luck my friend.
            • jiongpao
              • May 2009
              • 413
              Thanks you will note it down ..
