E007
  • Blues Guy
    • Aug 2009
    • 216
    [Error Code] E007
    Hi guys,
    I have a Canon iR2318L with these problem with error E007. Normaly these error code the faulty is at the heater assembly but the heater assembly everything is normal. Try reset the error but still the same.
    Some one told me is the DC p.c.b problem after changed the machine runs back in normal. I need few more comment from you guys before I made the order from Canon for DC p.c.b to replace it.
    Thank you for your comment if you have come across with these problem.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5013
    Re: E007
    Did you replace the Fixing Film?
    • Blues Guy
      • Aug 2009
      • 216
      Re: E007
      I did not replace the heater assembly. Using a multimeter to check there is continuity so I assume is in good condition.
      • zoraldinho
        • Mar 2008
        • 5013
        Re: E007
        I m talking about fixing film!
        E007 0000 Fixing film sensor failure
        The fixing film sensor is faulty.
        - Check the connector of the fixing film
        sensor.
        - Replace the fixing film sensor.
        - Replace the DC controller PCB.
        Usually is film worn out and need to be replaced!
        • Blues Guy
          • Aug 2009
          • 216
          Re: E007
          Thanks bro.............will check the sensor before jump to the conclusion is the D.C p.c.b faulty
