Hi guys,
I have a Canon iR2318L with these problem with error E007. Normaly these error code the faulty is at the heater assembly but the heater assembly everything is normal. Try reset the error but still the same.
Some one told me is the DC p.c.b problem after changed the machine runs back in normal. I need few more comment from you guys before I made the order from Canon for DC p.c.b to replace it.
Thank you for your comment if you have come across with these problem.
