CANON IR5000 E00061-0001 !
  • blazersnfkrz
    • Feb 2018
    • 5
    #16
    Re: CANON IR5000 E00061-0001 !
    Originally posted by teckat
    Check MSW2, the switch could be mis-adjusted or loose.
    next--------------------
    Disable potential control by going into service mode Copier > Option > Tempo > F-POT-SW. Now copies can be run.
    1) A solid black copy means laser is defective.
    2) A white copy means you should check the Primary corona and HVT.
    3) A good copy means you should check the Potential sensor PCB.
    may I know what is an HVT sir?
    • teckat
      • 16083
      #17
      High voltage transformer
      Read free online manual
      CANON IR5000 SERVICE MANUAL Pdf Download.
      • techandtrader
        • Jun 2016
        • 335
        #18
        To keep them running you can turn off potential control until you get a new Pot Control sensor and the tool but first try to polish or coronas.
        I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
