iR2018 Blank on Head
  • nochick
    • Jan 2012
    • 80
    [CQ] iR2018 Blank on Head
    Hi..
    I have 4 Canon iR2018 and 1 of them has a ploblem.
    - There's blank [white line] about 1.5 inch from left to right on the top of copy even when i print
    and i try on A4R and it's blank on the top about 1 cm. on the top of copy even when i print.
    - I check the lamp is light up when scan even on feeder
    - I check cable CCD [pull out and plug it again]
    - I check Toner is full
    - I check Drum Unit / Drum is not seem wrong and primary seem find so i clean it with dry cloth.
    - I check Toner unit it's seem fine no line or dot
    - I try to clear err or service record and it's looks like work but after a few copy it's Happen again !!!
    - I try to copy ratio 70% and the blank reduce by that ratio too.
    What i should check next ??
    Thank you
  • mramlawi
    • Jul 2011
    • 838
    Re: iR2018 Blank on Head
    try to stop the paper before enter the fuser uni and tell me is it the same ?
    70 percent it will be cylander problem but
    Distinguished road makes you jewel in rough
    • nochick
      • Jan 2012
      • 80
      Thank you for ur comment mramlawi
      May I ask you
      if the paper stop before enter the fuser unit there will no image on paper right? [it's gonna be blank]
      and how do i know it's still blank on paper head or not.
      Thank you
      • marc
        • Feb 2010
        • 56
        • charm5496
          • 2387
          May I ask you
          Thank you
          you will have unfused toner on your paper. You are looking to see if the toner is smearing off before it hits the furer unit. Your problem is probably happening in the development stage of the image formation. Either your developer is not carrying the toner to the drum or the laser is not writing to your drum unit.
          The cam for your developer could also be out of place not applying pressure on one side causing the light image as well. Post a sample of your problem as that will help us see what you are working on. Run a sky shot as well. This is a copy with the lid up so you get a solid black image across the page.
          • mramlawi
            • Jul 2011
            • 838
            exactly what Charm Said just open the platen and print a balck copy and then stop it before enter the Fuser see still the blank appear if yea check the Cam if broken and follow what Charm wrote .
            regards
            • nochick
              • Jan 2012
              • 80
              Thank you charm5496 and mramlawi
              I will try and come back again..
              Good to have people like you in this world.
              • charm5496
                • 2387
                not a problem.
                • mramlawi
                  • Jul 2011
                  • 838
                  Welcome any time
                  • sweet.persona
                    Engineer
                    • Nov 2009
                    • 415
                    you welcome
                    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
                    DAMENE ABDEL AZIZ
                    DJELFA
                    • nochick
                      • Jan 2012
                      • 80
                      Hello
                      charm5496
                      and mramlawi
                      I didn't check iR2018 yet because my customer call me in the morning that it's ok ....it's just normal ...
                      so i keep waiting a few day perhap it will be back
                      and today I going to service another customer with my father to fix NP6650 / I saw this machine since i was a child.
                      there some thing wrong with the image
                      it's blur and shift from left side about 2 inchs
                      my father
                      - check lens pass + clean
                      - rail scan and string too slack / but after tight it ....it's still the same
                      - blade too old / but no spare part so ....can't do any thing
                      - Drum my father suspect that some of old blade sticky on drum so I clean it
                      after all he suspect motor that drive rail scan
                      I didn't want answer but gladly accept any comment
                      thank you again charm5496 and mramlawi....
                      • charm5496
                        • 2387
                        the 6650 is an old mechanical beast. I sample of the blur would be helpful in troubleshooting
                        • ogitzz
                          i have problem just recently in one of my Canon ir2016j machine...blurred copy on right side portion about 2 inches down...
