iR5570 adjust each tray
  • tcwliao
    • Aug 2025
    [Misc] iR5570 adjust each tray
    Dear I know iR2020 can use service model to adjust each tray
    how about iR5570? please advise~~~many thanks
  • spectraindo
    • May 2008
    • 313
    Re: iR5570 adjust each tray
    iR5570 ,there is no adjustment for each tray in Service mode, you have to adjust each tray mechanically for Horizontal position of the paper.
    • tcwliao
      Thanks so much for your replied. But adjust mechanically a little bit tough to me >"<
      Vendor said need to change the control panel is it? Please advise~~~
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        What kind of adjustment?
        • teckat
          • 16083
          SERVICE MODE:
          COPIER> OPTION> CST> CST-U1
          31: G-LTR *, 22: K LGL
          COPIER> OPTION> CST> CST-U2
          24: FLSC *, 26: OFI, 27: E-OFI, 36: A-OFI, 37: M-OFI
          COPIER> OPTION> CST> CST-U3
          34: G-LGL *, 35: FOLI, 25: A-FLS
          COPIER> OPTION> CST> CST-U4
          18: LTR *, 29: A-LTR
          *: factory setting
          COPIER> ADJUST> CST-ADJ> C3-STMTR
          Use it to change the paper width basic value for STMTR in cassette 3.
          COPIER> ADJUST> CST-ADJ> C3-A4R
          Use it to change the paper width basic value A4R in cassette 3.
          COPIER> ADJUST> CST-ADJ> C4-STMTR
          Use it to change the paper width basic value for STMTR in cassette 4.
          COPIER> ADJUST> CST-ADJ> C4-A4R
          Use it to change the paper width basic value for A4 in cassette 4.
          - Paper Types That May Be Used for the Machine
          A3 A3 (297 +/- 1) x (420 +/- 1)
          A4R A4R (210 +/- 1) x (297 +/- 1)
          A4 A4 (297 +/- 1) x (210 +/- 1)
          A5 A5 (210 +/- 1) x (148.5 +/- 1)
          A5R A5R (148.5 +/- 1) x (210 +/- 1)
          B4 B4 (257 +/- 1) x (364 +/- 1)
          B5R B5R (182 +/- 1) x (257 +/- 1)
          B5 B5 (257 +/- 1) x (182 +/- 1)
          11 x 17 11 x 17 (279 +/- 1) x (432 +/- 1)
          LTRR LTRR (216 +/- 1) x (279 +/- 1)
          LTR LTR (279 +/- 1) x (216 +/- 1)
          STMT STMT (216 +/- 1) x (139.5 +/- 1)
          STMR STMTR (139.5 +/- 1) x (216 +/- 1)
          LEGAL LGL (216 +/- 1) x (356 +/- 1)
          Korean Government K-LGL (265 +/- 1) x (190 +/- 1)
          Korean Government R K-LGLR (190 +/- 1) x (265 +/- 1)
          FOOLSCAP FLSC (216 +/- 1) x (330 +/- 1)
          Australian Australian
          Foolscap A-FLS (206 +/- 1) x (337 +/- 1)
          OFICIO OFI (216 +/- 1) x (317 +/- 1)
          Ecuadorian Officio E-OFI (220 +/- 1) x (320 +/- 1)
          Bolivian Officio B-OFI (216 +/- 1) x (355 +/- 1)
          Argentine LTR A-LTR (280 +/- 1) x (220 +/- 1)
          Argentine LTRR A-LTRR (220 +/- 1) x (280 +/- 1)
          Government LTR G-LTR (267 +/- 1) x (203 +/- 1)
          Government LTRR G-LTRR (203 +/- 1) x (267 +/- 1)
          Argentine LGL A-LGL (220 +/- 1) x (340 +/- 1)
          Government LGL G-LGL (203 +/- 1) x (330 +/- 1)
          FOLIO FOLI (210 +/- 1) x (330 +/- 1)
          Argentine Officio A-OFI (220 +/- 1) x (340 +/- 1)
          Mexico Officio M-OFI (216 +/- 1) x (341 +/- 1)
          Manual Feed Tray
          SERVICE MODE:
          COPIER> ADJUST> CST-ADJ> MF-A4R
          Use it to change the paper width basic value for A4R in the manual feed tray.
          COPIER> ADJUST> CSRT-ADJ> MF-A6R
          Use it to change the paper width basic value for A6R in the manual feed tray.
          Use it to change the paper width basic value for A4 in the manual feed tray.
          Size of Paper (right/left deck)
          The right/left deck does not possess a mechanism to detect the size of paper, and the machine finds out the size of paper as follows:
          (A4, B5, LTR)
          [1] The position of the paper size guide plate of the cassette is changed.
          [2] A paper size is registered in service mode.
          SERVICE MODE:
          COPIER> OPTION> CST> P-SZ-C1
          Use it to specify a paper size for the right deck.
          Settings:
          6: A4, 15: B5, 18: LTR
          COPIER> OPTION> CST> P-SZ-C2
          Use it to specify a power size for the left deck.
          Settings
          • spectraindo
            • May 2008
            • 313
            Horizontal registration for all trays :
            COPIER > ADJUST > LASER > PVE-OFST
            For individual trays , read pdf file.
            Side Registration Adjustment.pdf
            • tcwliao
              Make the output image more upper or down
              in iR2020 we can thru service model =>printer=>numeric
              Tray 1 select 035 and entry a figure to adjust the out image more upper or down
              Tray 2 select 036 and entry ....etc.
              • tcwliao
                [ATTACH]13854[/ATTACH]
                Many thanks it's so helpful.
