OCE 3165 Compatible or Bulk toner
  • asirir
    • May 2009
    • 7
    [Misc] OCE 3165 Compatible or Bulk toner
    hi,
    I got OCE 2065. It use F11 toner.
    Is anybody know the formulation of OCE F11 toner?
    I want to make bulk toner for my printer/ copier.
    I think HP LaserJet 1100 series printer's toner will match to this?
    if anybody has idea. pl let me know.
    asiri
  • Hemlock
    • 432
    Re: OCE 3165 Compatible or Bulk toner
    Here's the ingredient list; get to mixing and tell us how it goes!
    “Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'” (Isaac Asimov)
    • sandmanmac
      • 3983
      Oh man.....Just when you thought you've heard it all...along comes asirir...hahaha.
      • asirir
        • May 2009
        • 7
        hi,
        anybody know "Low Fusing Temprature Toner" below 50 c?
        HP 12A toner work with oce but little smudge on around text.
        I think oce's fusing power is not enough
        please send me the name of low fusing temp. toner
        thanks!
        • sandmanmac
          • 3983
          Originally posted by asirir
          hi,
          [ATTACH=CONFIG]15142[/ATTACH]
          thanks!
          ima-cheap SOB works pretty well
          • seniortech
            • Dec 2007
            • 180
            On your head be it, if you use anything other than the toner recommended for the 3165 you will seriously damage your machine. prints/copies will initially may appear ok but very quickly the 'wrong toner' will completely contaminate the machine. You will need to replace the OPC,TTF and Delivery belts, TTF Cleaner and delivery unit cleaning sheets and infeed belts you will need to clean out or possibly replace the toner unit and OPC cleaning unit, dismantle and clean all the above units and completely vac out the whole machine.
            You have been warned...
              • 23010
              asirir: IMHO you are you're own worst enemy. =^..^=
