IR 6000
  • COPIERTEC ASSOCIATES
    • Aug 2011
    • 279
    IR 6000
    Hi to all comrades. Am working on IR6000 the paper cassettes 1 and 2 have failed to lift the decks.Checked the drive motors all fine, replaced sensors,cleaned all the gears and still failed to lift both decks.Assistance requested thanks.
  • doktor
    • 214
    Re: IR 6000
    Check out motor driver.
      • Aug 2011
      • 279
      Re: IR 6000
      Motor drive checked and is ok. The 24v are also present at the motor terminals
      • jiongpao
        • May 2009
        • 414
        Re: IR 6000
        Check the steel cable at the back of cassettes does it fall out of position?
        When closing the front decks make sure the lever can push high enough to lift the cam.
        cassette.pdf
        Try to change DC controller
