We are being shipped a fuser unit that will be replacing a malfunctioning unit. The tech, who cannot be in the area to help, said that it was a matter of unscrewing some screws and it was an easy replacement. Is this the case or is it more complicated than that? Does anyone have a walk through or guide for something like this? I appreciate your time.
Canon iR 5185 Fuser Replacement
Re: Canon iR 5185 Fuser Replacement
if you are just getting the fuser unit you will have to swap the fixing drive unit from the old one to the new one. The unit is held in by 4 screws and the drive unit is held on by a screw and a clip. I'm sure some one has a a PDF or something to help you out visually with the procedure, but it really isn't that difficult to do.Accidents don't just happen. They must be carelessly planned. -
Start by removing the fixing drive as Charm pointed out
irc5185i-sm.pdfComment
Remove the large black rear cover (two screws) which conceals the Fixing Drive Assembly.
When removed, unplug the connector and remove the three screws. See Figures 1 and 2.
Remove the 2 screws and connector.-------Remove the 1 screw located on the bottom of the
Fixing Drive. It is accessed from the interior of the copier. This picture is of the screw as viewed
from the inside of the equipment
Carefully remove the flexible black Panel Mount Cover and unplug the three connectors on top of the Fixing Drive Assembly.
Remove the two (2) plastic E-Rings,and slide the metal bracket to the right towards the Twin Belt Assembly .
fuser4.JPGfuser5.JPG After removal of E-Rings and bracket movement.
Remove the Fixing Drive Assembly from the Fixing Unit.
Remove the two (2) screws holding the Fixing Assembly to the drawer assembly and set the Fixing Assembly on a level area -------------------------------**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Removing Fix Unit
[ATTACH=CONFIG]14056[/ATTACH][ATTACH=CONFIG]14057[/ATTACH]
[ATTACH=CONFIG]14058[/ATTACH]
[ATTACH=CONFIG]14059[/ATTACH][ATTACH=CONFIG]14060[/ATTACH] After removal of E-Rings and bracket movement.
[ATTACH=CONFIG]14061[/ATTACH]
Remove the two (2) screws holding the Fixing Assembly to the drawer assembly and set the Fixing Assembly on a level area -------------------------------Accidents don't just happen. They must be carelessly planned.Comment
DID U PERFORM THIS BELOW IN SERVICE MODE ??????
after install of new unit--------------------------
Execute the operation of HP search of the fixing belt and the pressure belt
a. COPIER > FUNCTION > FIXING > FIX-UHP-S > OK
b. COPIER > FUNCTION > FIXING > FIX-LHP-S > OK
Clear the fixing delivery print counter
c. COPIER > COUNTER > DRBL-1 > FIX-BLT-U > CLEAR
d. COPIER > COUNTER > DRBL-1 > FIX-BLT-L > CLEAR
Points to Note When Replacing the Fixing Unit
In the case of executing HP search operation of the fixing belt and the pressure belt, the alarm code is closed, and the total rotating time of the fixing assembly is cleared.
Thus, make sure to execute this mode when replacing the fixing unit otherwise it may cause the following symptoms:
-The alarm code is not closed
06-0002: fixing unit life alarm (occurs by belt displacement)
06-0004: fixing unit life alarm (occurs by torque-up)
-The message is displayed for the machine misidentify that the total rotating time reaches the message threshold value although it does not.
Do not execute this mode other than when installing or when replacing the fixing unit. There may be no error indication although the fixing unit comes to the end of its life.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
but u need to clear that counter
FX-UHP-S Fixing belt (upper belt) displacement control auto home position search
Forces fixing belt (upper belt) displacement control and detects belt position detection sensor switching time. From that time, the home position displacement table is used to change the home position.
FX-LHP-S Pressure belt (lower belt) displacement control auto home position search
Pressure fixing belt (lower belt) displacement control and detects belt position detection sensor switching time. From that time, the home position displacement table is used to change the home position.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
