Canon iR 5185 Fuser Replacement
  • schwinnja
    • Apr 2011
    • 21
    We are being shipped a fuser unit that will be replacing a malfunctioning unit. The tech, who cannot be in the area to help, said that it was a matter of unscrewing some screws and it was an easy replacement. Is this the case or is it more complicated than that? Does anyone have a walk through or guide for something like this? I appreciate your time.
  • charm5496
    • 2387
    Re: Canon iR 5185 Fuser Replacement
    if you are just getting the fuser unit you will have to swap the fixing drive unit from the old one to the new one. The unit is held in by 4 screws and the drive unit is held on by a screw and a clip. I'm sure some one has a a PDF or something to help you out visually with the procedure, but it really isn't that difficult to do.
      Start by removing the fixing drive as Charm pointed out
      irc5185i-sm.pdf
      • schwinnja
        • Apr 2011
        • 21
        I appreciate the timely responses. Thank you for the PDF and letting me know about the fixing drive.
        • Simons
          • Jun 2008
          • 490
          I have a used fixing drive for sale. Doesnt have the metal clip around the connector but other than that its fine. Kinda superficial.
            • 16083
            Removing Fix Unit
            Remove the large black rear cover (two screws) which conceals the Fixing Drive Assembly.
            When removed, unplug the connector and remove the three screws. See Figures 1 and 2.
            Remove the 2 screws and connector.-------Remove the 1 screw located on the bottom of the
            Fixing Drive. It is accessed from the interior of the copier. This picture is of the screw as viewed
            from the inside of the equipment
            Carefully remove the flexible black Panel Mount Cover and unplug the three connectors on top of the Fixing Drive Assembly.
            Remove the two (2) plastic E-Rings,and slide the metal bracket to the right towards the Twin Belt Assembly .
            fuser4.JPGfuser5.JPG After removal of E-Rings and bracket movement.
            Remove the Fixing Drive Assembly from the Fixing Unit.
            Remove the two (2) screws holding the Fixing Assembly to the drawer assembly and set the Fixing Assembly on a level area -------------------------------
            • charm5496
              • 2387
              Originally posted by teckat
              Removing Fix Unit
              [ATTACH=CONFIG]14056[/ATTACH][ATTACH=CONFIG]14057[/ATTACH]
              [ATTACH=CONFIG]14058[/ATTACH]
              [ATTACH=CONFIG]14059[/ATTACH][ATTACH=CONFIG]14060[/ATTACH] After removal of E-Rings and bracket movement.
              [ATTACH=CONFIG]14061[/ATTACH]
              This is much better than the service manual!!!!!
              • Simons
                • Jun 2008
                • 490
                So much fun to do, sometimes raise blood pressure with those connectors.
                  Colour pictures and perfect English (unlike the service manual) nice one Teckat.
                  • Simons
                    • Jun 2008
                    • 490
                    I keep thinking and hoping he works for Canon inc. and is here to help the ones that dont have a direct link. Very much appreciated!
                    • schwinnja
                      • Apr 2011
                      • 21
                      Just wanted everyone to know that the switch was successful. I was able to change out parts without issue, mostly due to the great pictures and descriptions. I appreciate it.
                        • 16083
                        IMPORTANT !!!!!!!!!!!!!!!!
                        DID U PERFORM THIS BELOW IN SERVICE MODE ??????
                        after install of new unit--------------------------
                        Execute the operation of HP search of the fixing belt and the pressure belt
                        a. COPIER > FUNCTION > FIXING > FIX-UHP-S > OK
                        b. COPIER > FUNCTION > FIXING > FIX-LHP-S > OK
                        Clear the fixing delivery print counter
                        c. COPIER > COUNTER > DRBL-1 > FIX-BLT-U > CLEAR
                        d. COPIER > COUNTER > DRBL-1 > FIX-BLT-L > CLEAR
                        Points to Note When Replacing the Fixing Unit
                        In the case of executing HP search operation of the fixing belt and the pressure belt, the alarm code is closed, and the total rotating time of the fixing assembly is cleared.
                        Thus, make sure to execute this mode when replacing the fixing unit otherwise it may cause the following symptoms:
                        -The alarm code is not closed
                        06-0002: fixing unit life alarm (occurs by belt displacement)
                        06-0004: fixing unit life alarm (occurs by torque-up)
                        -The message is displayed for the machine misidentify that the total rotating time reaches the message threshold value although it does not.
                        Do not execute this mode other than when installing or when replacing the fixing unit. There may be no error indication although the fixing unit comes to the end of its life.
                        • schwinnja
                          • Apr 2011
                          • 21
                          I did neither of those things. However, I will be to that office on friday, at which time I'll run both of those. Thank you for the heads up!
                            • 16083
                            may be too late to run the fix hp function, u should have no problem in a new unit,
                            but u need to clear that counter
                            FX-UHP-S Fixing belt (upper belt) displacement control auto home position search
                            Forces fixing belt (upper belt) displacement control and detects belt position detection sensor switching time. From that time, the home position displacement table is used to change the home position.
                            FX-LHP-S Pressure belt (lower belt) displacement control auto home position search
                            Pressure fixing belt (lower belt) displacement control and detects belt position detection sensor switching time. From that time, the home position displacement table is used to change the home position.
