Ir 8500 showing suspended
  • nasertop
    • Aug 2011
    • 40
    Dear Friends,
    I facing a problem with IR8500.As soon as if i press start key, the machine will scan, but during pickup,the machine will run & after that it will give paper jam,in display it shows suspended.
    I had changed DC controller,HV board,Fixing Feeder assy,Laser unit,Reader controller.Whether it could be a problem from mechanical portion. can you please guide me what i have to do.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Ir 8500 showing suspended
    Try to disconnect finisher or puch unit.Also can be a door swich issue.
    • Rachid.Akli
      • Oct 2011
      • 595
      I once had a similar issue with an IR5065. The reason is due to the stappler cartridge which was not well installed.
      Rachid.
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
      • Matoku
        • 173
        Check you platen glass. Is it inserted correctly. It must hit the sensor at top left corner. If not so then you reinsert the platen glass.
