canon np6317
  • walidcharifi
    • Feb 2011
    • 379
    canon np6317
    hi
    i have np 6317
    wholosethe toner to thefile corona
    She quickly consumed toner
  • gensys
    • Jan 2011
    • 324
    Re: canon np6317
    Originally posted by walidcharifi
    hi
    i have np 6317
    Change a toner
    use <<Katun>> toner
    The Road will be Mastered by >>> the Going...
    • walidcharifi
      • Feb 2011
      • 379
      Re: canon np6317
      Originally posted by gensys
      Change a toner
      use <<Katun>> toner
      yes
      i use katun toner
      • Rachid.Akli
        • Oct 2011
        • 595
        Re: canon np6317
        If i remember well, this model does have preconditioning lamps but not blank exposure lamps. Try to use the machine with front door open and program at least two copies then stop the copy-cycle between successive copies. Verify the image on the drum. In normal conditionns, there shouldn't be any image. If it is'nt the case, it means that the drum is beeing charged between successive copies and this results a high toner consumption. Your High Voltage "box" doesn't "put" the charging corona grid to ground. So, just change the whole HV PCB box.Rachid.
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
