Canon ImagePRESS Server Q1
  • manuelubau
    • Aug 2011
    • 62
    Hello,
    I have an ImagePRESS Server Q1 that is not working. I think the Hard drive might be damaged or something. The server's display is in blank and not working. I tried to plug the server to a monitor and it didn't work either. is there a way to configure an empty hard drive so it works as the original? if so what kind of software is used? I know it is a software called Fiery something. any help would be appreciated.
    Thanks,
    Manuel Ubau
  • teckat
    • 16083
    Re: Canon ImagePRESS Server Q1
    Originally posted by manuelubau
    Hello,
    Thanks,
    Manuel Ubau
    When turning the Server on, there is no front display and no VGA to an external monitor.
    have u opened the box to inspect interior ??????????
    Before replacing the Motherboard, try replacing or checking the memory.
    Replaced the Mother Board PCB (FE1-6111-000) and utilized the Update Software. After installing the new mother board you will connect the dongle that comes with the mother board and power the server on. At this point you can verify if the mother board has fixed the problem. If the problem is resolved you need to run the Update Software CD that comes with the mother board to complete the repair.
    The activity light on the imagePRESS Control Panel indicates current imagePRESS activity.
    Flashing Orange = The imagePRESS is starting up and the BIOS has established communication with the User Interface Board (UIB).
    Flashing Green = The imagePRESS is continuing start up and the Windows XPe operating system has established communication with the UIB.
    Solid Green = The imagePRESS is powered-on and in an idle state.
    Solid Yellow = The imagePRESS is powered off but the AC power cable is plugged into the power source. The Control Panel LCD continues to draw power when the imagePRESS is powered off.
    Flashing or Solid Red = An error has caused printing to be disabled.
    No light = The imagePRESS is powered off and the AC power cable is not connected to a power source.
    • manuelubau
      • Aug 2011
      • 62
      Sorry I actually tried again to make sure there was no video output and found out that there IS video output. but when windows is loading, blue screen appears.
      • teckat
        • 16083
        did u open the box to inspect interior ???
        READ>>>>>>>>>>>>
        • manuelubau
          • Aug 2011
          • 62
          I did open it... everything seems fine... I bought this sever with the ImagePRESS C1 to a dealer. it was used and the dealer didn't have the CD's to configure the ImagePRESS server.
          • alexctx
            • Dec 2010
            • 157
            seems to be the HD, buy a 160 gb hd ide more.
            and calls. canon.
            have to install and update software.v1.1 online.
            where are you
            • manuelubau
              • Aug 2011
              • 62
              Nicaragua... there is no canon support here. any idea how I can get the software? I tried searching in the Canon website but no luck...
              • alexctx
                • Dec 2010
                • 157
                mandame una foto real del equipo y te ayudo sabes clonar disco yo tengo la imagen , que modelos de equipos vez
                • manuelubau
                  • Aug 2011
                  • 62
                  ese es el server. Si puedo clonar CD's. seria muy bueno si me puedes enviar la imagen del CD. Muchas Gracias!
                  • teckat
                    • 16083
                    [ATTACH=CONFIG]14211[/ATTACH]
                    just looking in box will not tell u anything/
                    did u do the memory test i listed/ did u check & remove > connectors ??
                    these boxes do not all of a sudden lose it's firmware
                    • manuelubau
                      • Aug 2011
                      • 62
                      I did clean, disconnected, and connected everything. The server is only showing a flashing orange light. and it doesn't change.
                      • alexctx
                        • Dec 2010
                        • 157
                        no tengo la imagen del disco duro pesa casi un 1gb mi correo es alexctx@hotmail.com distibuidor de canon alli CANON LATIN AMERICA, INC. solo que es caro cuanto te costo tu imagepress c1 con q1 dimelo en dolares americanos us$ esres usuario final o tecnico de copiadoras
                        • teckat
                          • 16083
                          for Flashing Orange = The imagePRESS is starting up and the BIOS has established communication with the User Interface Board (UIB).
                          Re-check all cables and connections. Make sure that the HDD data cable is connected to the correct SATA port (J19) on the motherboard
                          Try to replace the HDD SATA cable
                          could also have a damaged UIB
                          User interface board (UIB) is:
                          Conditions to verify
                          • alexctx
                            • Dec 2010
                            • 157
                            ponle monitor ,mouse ps2 y teclado ps2 al comienso debe detectar las memoria ,disco lueguo debe empesar a cargar el xp es uno integrado con el fiery no es el que venden para pcs .
                            si sale una pantalla de error parecida a esta tu disco duro esta mal hay cambiarlo y reinstalar sistema pon una foto en que pantalla se queda cuando tiene monitor.
                            • manuelubau
                              • Aug 2011
                              • 62
                              When i connect the box to a monitor, windows starts loading and then this image appears
                              I did check if the Hard drive was correctly connected and it was.
