Error Code E000004-0205 Canon IR7500
  • RichieAugust
    • Jul 2011
    • 18
    Does anyone know what this error code means?
    Thank you!
    Richie August
  • teckat
    • 16083
    Re: Error Code E000004-0205 Canon IR7500
    Thank you!
    Richie August
    What is a iR7500 ??
    • gensys
      • Jan 2011
      • 323
      Check the rotation of the fixing motor (the connector is physically removed or disconnected)
      -> replace the fixing motor or the harness
      The connectors of the pressure sub thermistor (THM2, 3, 4) are physically removed (the cable is caught, or disconnected)
      -> replace the thermistor or the presure stay
      Disconnection, soiled, improper location of, or faulty pressure sub thermistor
      -> clean the thermistor or replace it.....
      The Road will be Mastered by >>> the Going...
      • teckat
        • 16083
        What is a iR7500 ??
        • Smiley27
          • Apr 2011
          • 160
          That is good question ..
          Originally posted by teckat
          What is a iR7500 ??
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5015
            What is a iR7500 ??
            http://www.copytechnet.com/forums/ca...05-ir7055.html
            • teckat
              • 16083
              • gensys
                • Jan 2011
                • 323
                What is a iR7500 ??
                RichieAugust was mistaken
                it is 7200 or 7055
                Anyway a thermistor problem most likely
                • vigour
                  • Aug 2010
                  • 1038
                  gensys did you get trained on 7500.
                  THe guy corrected his mistake and started a thread for 7055
                  • gensys
                    • Jan 2011
                    • 323
                    There is no difference be it a ir7500,7999,ir785158777 or the 7200 . For a series 7000 error code same
                    • zoraldinho
                      • Mar 2008
                      • 5015
