Canon IRC 2030 E000074-0000
  • Canuck
    Tech Specialist
    • 1713
    Re: Canon IRC 2030 E000074-0000
    I've had these out...what a pain in the ass. Cams for shutters at bottom of assembly have to be synchronized properly...line up the little holes, half holes,...what a pain
    • niyaskarimba
      • Sep 2014
      • 110
      Originally posted by pcernicky
      It was the switch , the error code is gone, but I need to confirm the copy quality issue.
      Thank you.
      The color copy quality is really bad, color is off and light horizontal lines, check the sky-shot on the black drum and it's grey not solid black plus i see 2 inch void area around drum.The drum unit is brand new.
      Just want to confirm that the issue is ITB unit.
      Copier has 10k copies, but it wasn't working right for couple months and also some other guy was playing here with the copier.
      Thank you for advice.
      Did you replaced the switch..??or it just mis positioned only??
        dead thread.. look @ date stamp!
        • pcernicky
          • Feb 2010
          • 66
          #19
          HI,
          yes the switch was replaced, was not engaging fully, the contact was on and off. New switch solved the issue. Hope this helps.
          • joenaicker
            #20
            Can anyone help me out with Primary Transfer Disengagement Switch on Canon Image Runner Advance C2030.
            I would like to know where is the switch located and how to replace it.
            Joe
              Originally posted by joenaicker
              Can anyone help me out with Primary Transfer Disengagement Switch on Canon Image Runner Advance C2030. I would like to know where is the switch located and how to replace it.
              Thanks Joe
              well clearly you didn't READ THE DEAD THREAD..
              sw01
                • 16083
                #22
                Joe
                Primary Transfer Roller Disengagement Control
                The Primary Transfer Roller is usually engaged. The Primary Transfer Roller needs to be disengaged when a part is replaced; otherwise, the ITB can contact with the Drum Unit.
                The timing to make the Primary Transfer Roller disengaged
                • At the time of shipment
                • In the case of selecting the ITB/Drum Unit replacement in service mode or user mode
                The timing to make the roller engaged
                • At power-on
                • At recovery from sleep mode
                • When the Front Door is opened/closed
                The roller is engaged after the roller is once disengaged.
                Related service mode:
                • Execution of the Primary Transfer Roller disengagement
                COPIER > FUNCTION > MISC-P > T1-UP
                Related user mode:
                • Execution of ITB/Drum Unit Replacement Mode
                Adjustment/Maintenance > Maintenance > ITB/Drum Unit Replacement Mode > Start
                The above mode is displayed by selecting the following in service mode:
                COPIER > OPTION > DSPLY-SW > ITB-DSP > 1 (default: 0)
                • JPiek
                  • Oct 2014
                  • 435
                  #23
                  Eat, Sleep, Post, Repeat
                  Johan
                  • luis1984bol
                    • Nov 2011
                    • 155
                    #24
                    The timing to make the Primary Transfer Roller disengagedThe roller is engaged after the roller is once disengaged.
                    Related service mode:[ATTACH=CONFIG]42726[/ATTACH]
                    Hello, that means the SW1 and SL1 are located inside in the ITB?
                      • 16083
                      #25
                      NO part # for SW1---need to order MAIN DRIVE ASSEMBLY
                      SW1 ( Primary Transfer Disengagement Switch) for Displacement )
                      on REAR Plate-- SW1 ( Primary Transfer Disengagement Switch) for Displacement, Replace the Main Drive Assembly if Needed, FM4-7716-000.
                      SL1 is part of the Fixing Drive Assembly and is not available as a separate part.
                      The Fixing Motor is involved in both the operation of the Fixing Assembly and the Primary Transfer Disengagement.
                      FM0-1158-010 ----------------Fixing Drive Assembly
                      • luis1984bol
                        • Nov 2011
                        • 155
                        #26
                        Thank you very much. I have a problem with a iR ADV C2230. Error E0074-000. Fisrt, I will replace the ITB Unit, I hope that fix the problem. Thank you. I will let you know how it works.
