you can change server T1 in server H1 ?
  • DANIELCANON
    • Jun 2011
    • 187
    Hello everybody, quiero saber si es posible convertir un servidor T1 en servidor H1 o viceversa ya que noto que fisicamente tienen el mismo harware.
  • charm5496
    • 2387
    • DANIELCANON
      • Jun 2011
      • 187
      Re: you can change server T1 in server H1 ?
      alguien sabe si es posible la conversion de T1 a H1 o viceversa?
        • 16083
        H1///Open I/F PCB----FM2-7430-000
        T1///Open I/F PCB----FM2-7360-000
        What about the printer open interface boards needed ???
        & Bios ver's
        H1 /// BIOS (U530)
        The BIOS chip is located in the PLCC32 socket on the motherboard at U530 .
        The BIOS chip contains boot information.
        It is not necessary to transfer the BIOS chip when replacing the motherboard.
        (If you replace the motherboard, it is not necessary to transfer the BIOS or the Mac chip set from the old motherboard. It is necessary to transfer the Key chip.)
        Key chip at U7201//If you must install a different MAC chip set onto the motherboard, the system administrator may need to reconfigure the IP address in Setup.
        T1/// BIOS (U530)
        The BIOS chip is located in the PLCC32 socket on the motherboard at U530.
        Key chip in U7201
