Hello everybody, quiero saber si es posible convertir un servidor T1 en servidor H1 o viceversa ya que noto que fisicamente tienen el mismo harware.
you can change server T1 in server H1 ?
Tags: None
Re: you can change server T1 in server H1 ?
alguien sabe si es posible la conversion de T1 a H1 o viceversa?Comment
H1///Open I/F PCB----FM2-7430-000
T1///Open I/F PCB----FM2-7360-000
What about the printer open interface boards needed ???
& Bios ver's
H1 /// BIOS (U530)
The BIOS chip is located in the PLCC32 socket on the motherboard at U530 .
The BIOS chip contains boot information.
It is not necessary to transfer the BIOS chip when replacing the motherboard.
(If you replace the motherboard, it is not necessary to transfer the BIOS or the Mac chip set from the old motherboard. It is necessary to transfer the Key chip.)
Key chip at U7201//If you must install a different MAC chip set onto the motherboard, the system administrator may need to reconfigure the IP address in Setup.
T1/// BIOS (U530)
The BIOS chip is located in the PLCC32 socket on the motherboard at U530.
Key chip in U7201Last edited by teckat; 10-12-2012, 07:21 PM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
