Canon imageclass mf5750 paperjam
  • screwdriver08
    • Jul 2010
    • 160
    [Jamming] Canon imageclass mf5750 paperjam
    WHEN I TRY TO MAKE "1" A SINGLE COPY ON MY CANON IMAGECLASS MF5750, IT ALWAYS JAMS AFTER HALF OF THE PAPER HAS EXITED OUT OF THE FUSER, AND ALSO ANOTHER PAPER JAMMED UNDERNEATH THE TONER CARTRIDGE (EVEN THOUGH I MADE ONE COPY). INSTEAD OF PICKING UP ONE PAPER TO MAKE MY SINGLE COPY IT PICKS UP TWO AND THEN JAMS BEFORE THE FIRST ONE IS OUT...CAN YOU PLEASE HELP ME, THIS IS DRIVING ME CRAZY. DOES ANYONE HAVE THE MANUAL FOR IT?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5000
    Re: Canon imageclass mf5750 paperjam
    Take off right plastic cover and replace broken spring.
    • screwdriver08
      • Jul 2010
      • 160
      Originally posted by Canon.Tech
      I have seen this so many times on this & a few other models with the same engine, surely Canon has brought out an official fix by now!?
      Thanks zoraldinho,
      I found the spring...although I did stretch it, the paper still Jams. Just like before. It still makes two copies instead of one and they both Jam.
      • zoraldinho
        • Mar 2008
        • 5000
        Thanks zoraldinho,
        When picking up paper from the cassette, the paper pick-up roller may make several rotations, causing a paper jam.
        <Cause>
        In the paper pick-up operation, a stop of the paper pick-up roller is controlled by letting the pawl of pick-up solenoid [B]
        engage with the cam [C] of 25T gear [A]. Because of this mechanism, a mix of a few reasons such as variance of parts
        generated during production and the assembly condition of parts can cause the pawl to fail to engage with the cam,
        causing several rotations of the gear. If this occurs, the paper pick-up roller repeats the paper pick-up operation
        continuously, causing a paper jam.
        Service work:
        When the foregoing symptom occurs, replace the pick-up solenoid by the new type. The last 2 digits of the part number
        printed on the solenoid show the revision number: ‘01’ means the old type solenoid, and ‘02’ means the new type.
        FH6-5132-020
        • screwdriver08
          • Jul 2010
          • 160
          [ATTACH=CONFIG]14377[/ATTACH]
          <Cause>
          [ATTACH=CONFIG]14378[/ATTACH]
          Service work:FH6-5132-020
          [ATTACH=CONFIG]14383[/ATTACH]
          Thanks for the Help,..Do you know where I can buy this parts?
          • zoraldinho
            • Mar 2008
            • 5000
            From Canon dealers around you.
            • zoraldinho
              • Mar 2008
              • 5000
              Don't do this on the field.
              • screwdriver08
                • Jul 2010
                • 160
                I know this is a different copier but I just wanted to post this since you guys have helped me with my other canon copier. My Canon Imageclass D761 is displaying E000, and I have read online that you can remove the error in the service mode...but my problem is I do not know how to get into service mode. does any of you know?...thanks
                • joboggi
                  Canon imageCLASS MF5750 Spring For DS Arm, Genuine (A9639)
                  Canon FH6-5132-020 (FH6-5132-000) Pickup Solenoid, Genuine (J6209)
                  Are these the two parts mentioned above. I am having the same problem.
                  • copier tech
                    • 8103
                    I have seen this fault many times, this is the same engine on a few older Canon desktop models.
                    It is the sound dampening pad on that pick up solenoid, it gets sticky & causes the pick up solenoid to stay on for a second or 2 longer.
                    If you take off the side cover, take out the cassette you can just see the solenoid enough to remove the pad with a pin, paper clip etc. No need to order parts.
