iRC3380 , Repetitive Yellow Claw Marks along edges
  • Victor285
    • Jul 2010
    • 61
    [CQ] iRC3380 , Repetitive Yellow Claw Marks along edges
    I am getting the following marks on the copies and print tests. Has anyone seen these or could point me in the right direction. The marks repeat along each side about 50mm apart (2 in.). Only happens when printing color and only Yellow. Could this be mag roller in Yellow drum? I appreciate all responses.
    Thanks,
    Vic
  • mjarbar
    Re: iRC3380 , Repetitive Yellow Claw Marks along edges
    The fact it happens on the yellow only on your print samples would indicate the yellow drum is at fault, and would replace accordingly.
    If you do a single colour test page or cingle colour copy on anything other than yellow do you still get marks?
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Replace yellow cartrige.Inspect ITB (yellow transfer roller).Check drum life in service mode.Print PG-10 test.
      • Victor285
        • Jul 2010
        • 61
        Thanks for response. Customer is running partial staffing at time. Will check Tomorrow on Toner change and ITB. Drum Life, etc. Did run a PG10 test - Yellow. See attached, Thanks!
          • 16083
          pattern repeats are exactly the same image
          YELLOW DRUM
