My customer have fax L220 with send issue.Always bussy.Recieve is OK.But this fax working just fine in my shop.I plug a new fax in my customer office and work without problems.Try to turn off ECM,slow down recieve speed,check all setings and made all clear.No luck.Any help please?!
I need fax expert
Re: I need fax expert
Is it an analog line or PBx? Most of the newer Kyocera have settings to accommodate communication across PBx. Maybe Canon too?
Could it be as simple as dialing a 9 prefix to get an outside line?
Or how about adding a pause or two after the 9 to allow a few more seconds for the line to connect? If the T1 timer (35 seconds) is timing out, you can add a few pauses after the phone number to increase the T1 value. The T1 timer does not start counting until the last digit is dialed, even if that last digit is a pause.
Have you put a phone tester on the line and looked at the values? =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Originally posted by Canon.TechI would suspect the line is at fault. As said above, plug a handset into that line, make a call, and listen to the quality, any crackles?
Also move the machine to another phone line just temporary to test, if it sends.receives OK advice customer to call their phone company get their line checked.Comment
