error code 000003-000 canon 2318
  • RWAFA
    • Aug 2011
    • 68
    i have my canon 2318 which showing error 000003-00 what could be the problem,please help.
  • copymech
    • Sep 2011
    • 196
    • montana
      • Aug 2008
      • 392
      Re: error code 000003-000 canon 2318
      try to clear this error by entering the service mode press additional function+# then choose clear press ok then choose ALL press ok the machine will reboot if the code appears again so i guess you have to replace
      the fixing heater element....i wish you good luck
      • Rachid.Akli
        • Oct 2011
        • 595
        "Clear all" won't clear the error code E0003.
        To clear the error, execute the following in service mode:
        COPIER>FUNCTION>CLEAR>ERR (already posted by copymech)
        Rachid
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
        • arielcanon
          • Mar 2012
          • 106
          Rachid
          it just standard 2 lines display brother, you won't find it...
          Learning never ends..
          Never give up, where there is a wheel there is a way..
          • mrfixit7
            • Jul 2018
            • 40
            settings registration 2 and 8 settings registration ...as usual then
            clear, engine, error clear
            turn off and on
