canon ir3300 jam wen making duplex
  • universaltvm
    • May 2010
    • 52
    Re: canon ir3300 jam wen making duplex
    i tried up to 80gsm paper but i want to clear the problem using 80 gsm paper bcoz in india 100 gsm will cost is too high than 80gsm
    • Rachid.Akli
      • Oct 2011
      • 595
      Originally posted by Canon.Tech
      Look at the quality of your paper, if a single side copy is curled when it comes out that is your problem, as when it passes through the duplex it will catch on the turn at the top of the cassette deck & jam.
      Try 100GSM paper as a test.
      [ATTACH=CONFIG]14472[/ATTACH]
      Dear all,
      As pointed above, this jam is mainly due to your paper quality. In addition to that, it might be damp because of being badely packed or present in the drawers for days. As the machine works in recto, there no need to change any sensor in the recto paper path. So, use another type of paper or, even, try a heavier one just to show that to your custmer.
      Rachid.
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
      • Young083
        There is an "unofficial modification" for duplex jamming. Take out your tray 1&2 paper feed unit, there is a plastic guide that the paper passes over, part of the guide has a gap in it, you need to cut and sellotape a piece of assotate to cover this gap. Slightly hard to explain without diagrams but you should see what I mean once you have the feed unit out.
        Cheers.
        • COPIERTEC ASSOCIATES
          • Aug 2011
          • 279
          #19
          Originally posted by teckat
          did u inspect the flag for this sensor/
          delay jams> work your way back from this sensor
          follow a check list procedure to trace
          I still believe that the flag of the duplex sensor does not go back to the home position within a specified time thus the jam in the duplex.Try to tension the flag spring for better results.
          • Rachid.Akli
            • Oct 2011
            • 595
            #20
            Hi everybody
            The jam code is 0122:
            01: for delay jams.
            22: duplex output paper sensor (PS18)
            If any of the flags doesn't go back to its home postion, the display jam code would be a stationnary one (02xx).
            Rachid.
            • ernesto
              • Oct 2011
              • 430
              #21
              Cheers.
              i did it becuse sometimes jamming or wrikled paper when the unit duplex was working
