IR3300 white line at black copy
  • urangsunda
    • Nov 2011
    • 13
    [Misc] IR3300 white line at black copy
    im use canon ir3300, can this fix it?
    thank
    **we big family, yayrahmah ... special thank to bpk jonih/ibu**
  • COPIERTEC ASSOCIATES
    • Aug 2011
    • 279
    Re: IR3300 white line at black copy
    Which particular cassette are you using?ie A4 orA4R? If you are using A4,try to ascertain the distance between the white line,thus it could be the drum cylinder or the developing cylinder on the developing unit.If you are using A4R,check the distribution of toner on the dev unit.Try to clean all the optics and the laser unit as well.
    • bineshpaul
      • Jul 2010
      • 43
      thank
      check the magnet roller, it may be damaged.
      Regards
      Binesh
      • urangsunda
        • Nov 2011
        • 13
        I've been cleaning the magnetic dev but the result is still the same.
        any solution?
        • Young083
          Hi mate,
          There could be hard toner in behind your mag roller. Try inserting a small piece off folded paper In the top and underneath your mag roller and moving it back and forward a few times to clear the hard toner that may be causing this.
          Cheers.
          • Brian8506
            • 1664
            That pattern looks too wide to be dv. Looks like a drum problem. How many copies on the drum and have you tried changing it?
            • Young083
              Sorry, never noticed the sample. Yeah, it's looking like your drum, I'd try that first.
