Change service mode key combination
  • m43l
    • Mar 2011
    • 14
    how to change combination key *28* in canon ir5000?
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Re: Change service mode key combination
    Why would you even want to? Either way......don't believe it's possible on that model.
    • Ctl-Alt-Del
      • Jul 2006
      • 430
      at least you're not asking to reset the meters.
        • 23008
        That will be post #2. =^..^=
        • Herrmann
          • Jan 2006
          • 792
          Not possible on that model, but in general, it is possible on several canon boxes, search for "SVMD-ENT" in the service mode / Options.
          you have the choice between *28* and *48*
          If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
          • m43l
            • Mar 2011
            • 14
            thanks for all information.
            i have trying it and successfully for ir6570
