ir5055 E001 ERROR
  • TCA TECH
    • Mar 2009
    • 104
    [Error Code] ir5055 E001 ERROR
    hI ALL,
    I have a ir5055 with 1.8mil on it.
    Intermittent error E001-0001
    I have replace all thermistors, door switches, upper and lower roller, all looks ok.
    Any ideas would be great
    Bernard
    Copiers are only as good as there last service
  • linuxxpwin
    • May 2008
    • 205
    Re: ir5055 E001 ERROR
    Normally this error refers to the fixing assembly, however intermittent power issue ca also cause this issue. failing ac driver, bad connector. all are possible causes.
    • linuxxpwin
      • May 2008
      • 205
      were you able to do a nip check on your rollers?
      • TCA TECH
        • Mar 2009
        • 104
        No Nip eck but cant see how that could make too much difference as the temo is taken from upper roller, error also accurs while machine in idle mode too
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          Do you have an upper fuser section to test in the machine?
          Either refurbed or new preferably.
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5015
            clear error.
            • TCA TECH
              • Mar 2009
              • 104
              Hi all, thanks for the feedback,
              I am now getting 0B00 jams to and we need to turn machine on and off to clear, jam says fuser area.
              I have ordered a connector and wiring loom as I think the connection is being lost, I will also swap fuser too as suggested with a spare I have.
              More ideas accepted
              • vigour
                • Aug 2010
                • 1038
                These fusers are a pain ,. You can replace everything and still get Ecodes.
                Try replacing the heater unit.
                If that does not work, you need a different fuser as OZE says refurb or new.
                • TCA TECH
                  • Mar 2009
                  • 104
                  So true
                  • TCA TECH
                    • Mar 2009
                    • 104
                    Hi all,
                    REplace wiring loom for the FIXING/FEEDER FRAME ASSEMBLY, 2 weeks no issues and now error and 0B00 jam again. It still looks like machine has an issue in the fuser area. Going to now order upper fuser assembly and replace. Wish me luck or add any idea's please
                    • vigour
                      • Aug 2010
                      • 1038
                      If it comes back after replacing the fuser, then you have to replace the matching harness on the machine rear frame.
                      • TCA TECH
                        • Mar 2009
                        • 104
                        Yes, hve done on a ir5000, makes good photo and talking point too
                        • TCA TECH
                          • Mar 2009
                          • 104
                          REplaced fuser 3 weeks ago, so far so good
                          • CanonSco
                            Man About Town
                            • Jul 2010
                            • 368
                            Cheers for the update.
                            Yes, I am a nerd.
                            Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
