different finishing trays
  • johnm@ucopier.com
    • Jun 2010
    • 46
    Do you happen to know how to get the printer to put different print
    jobs in different finishing trays?
  • vigour
    • Aug 2010
    • 1038
    Re: different finishing trays
    what model?
    what finisher?
    I don't think what you want to do is possible.
    The adjustment under additional functions> commmon settings> output settings
    allows you to send ALL print to a secific ray, ALL copy to another tray, All fax, mailbox,or other to another tray.
    The DEFAULT sends a mix of copy and print to EITHER tray, as the copier decides.
    • teckat
      • 16083
      the model is--------------please broadcast to receive radio wavesgoogle-heinrich-rudolf-hertz-doodle-full-220212.jpg
      • johnm@ucopier.com
        • Jun 2010
        • 46
        Hahah sorry . It's an IR5000 with an F1 finisher
        • Brian8506
          • 1665
          Addl func/common settings/tray designation. Hopefully thats what you're looking for
          • costd
            • Jan 2008
            • 409
            Not sure if this is what you mean:
            If I have a print job I want to go to tray A, then in the printer driver, finishing settings, I can change Auto to A - or B if that is what is wanted.
            So, I suspect they can go into their document and set the printing default (for that document) to the tray they want.
            Maybe Jim wants to send his stuff to tray B all the time - set his print driver default output to B.
            Just make sure you do set the tray designations to allow printer output to the trays you want.
            • teckat
              • 16083
              I believe once the trays are set for the Finisher output on the control panel (PRINTS-COPIES-OTHER) u can not select from print driver to switch over for convenience at a workstation.
              All operations involved in these modes are controlled by the finisher controller PCB, according
              to the appropriate commands from the host machine
              Modes
              Non-sort: trays 1 and 2
              Sort: trays 1 and 2
              Staple: trays 1 and 2
              • Brian8506
                • 1665
                But maybe if tray designation is set for both trays to accept print jobs you may be able to. One way to find out. Go try it.
                • teckat
                  • 16083
                  good point/
                  but if u have copy set for either tray it would mix with prints
                  or /You can set up the printing priority feature-
                  A job that is set to a high priority is printed preferentially after the job currently being performed.
                  when printing documents sent from a personal computer for Local Printing-
                  after pressing the [Change P Settings] key on printer
                  only option for Finisher is--
                  Finisher
                  -With the Finisher
                  Do not Collate/ Collate/ Offset Collate*/ Group/ Offset Group/ Staple (Corner (TopLeft/ BtmLeft/
                  TopRight/ BtmRight), Double (Left/ Right))
                  -With the Finisher+Puncher Unit-B1
                  TopRight/ BtmRight), Double (Left/ Right))/ Hole Punch
                  -With the Copy Tray-C3
                  Do not Collate/ Collate*/ Rotate Collate/ Group/ Rotate Group
                  for PS Printing/ driver
                  Finishing Option
                  available output options are:
                  NOTE
                  The available finishing options vary, depending on the output options attached to the printer.
                  • When a Collate option is available in the [Print] dialog box of the application software, the Collate option setting of the printer driver has priority, regardless of the same setting in the application software. However, in some application software, output is collated when
                  the collate option is selected in the application software even if the Collate option is not selected in the printer driver.
                  • To output document pages using the Group option, you must select [Group] in the printer
                  driver, regardless of a group option setting in the [Print] dialog box of the application software.
                  Collate Outputs sorted copies of the document in correct binding order into the output tray.
                  Group Outputs document pages in groups into the output tray.
                  Staple Outputs stapled copies of the document into the output tray.
