and stabilize the color in the ip 7000 vp
  • luisalberto9999
    • Feb 2012
    • 3
    [Misc] and stabilize the color in the ip 7000 vp
    newsletters help with this thanks
    700 prints each color is not maintained
  • vigour
    • Aug 2010
    • 1038
    Re: and stabilize the color in the ip 7000 vp
    This may be a stupid question, but:
    Have you done autograd and calibration yet.
    • luisalberto9999
      • Feb 2012
      • 3
      ok I understand wanting to be more specific.
      every day is the automatic adjustment of the scanner as three plies internal adjustment printer mode 5 leaves.
      internal temperature 7000vp is 35 degrees Celsius, the developing units are new, the drums are new.
      even so the color does not convense, my impression is coverage of a minimum of 30% for each color, and priority is 300 grams in paper format 13 X 19.
      the circulation that varies the color is 300, the color is low, I get the impression that feeds little toner , does not give me any code or any alarm.
      average densities in the four colors is -2
      Thanks for the suggestions
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        -install last system software 88.03
        -check drum temperature (35-37 c)
        -check posted setting for image-related issues
        ipc7000vp-048.pdf
