canon ir 105
  • Saji
    • May 2010
    • 97
    canon ir 105
    canon ir 105 showing e 246-002 error, wht could be the prob, please help, ( machine is in a far away place, i want to be prepared before attending the machine.) thnakns in advance.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: canon ir 105
    Reading from/ writing to the soft counter memory cannot be done properly.Probably DIMM issue.
    • Saji
      • May 2010
      • 97
      Re: canon ir 105
      Thank you Sir.
      • teckat
        • 16083
        Re: canon ir 105
        READ THIS----
        E246=Error in writing operations (to the counter memory).
        1. A normal soft counter reading cannot be written to the counter memory.
        2. Counter Memory PCB not being recognized on power up
        Action
        1. Re-install original Counter Memory PCB that belongs to that equipment.
        2. Replace Counter Memory PCB with new one.
        iR105 PART # FOR COUNTER MEMORY PCB.= FG3-3169-000
        If replacing the Counter Memory PCB does not fix an E245, E246 or E247 code, suspect a failed Main Controller PCB (put back the original Counter Memory PCB when replacing the Main Controller PCB).
        Results
        All counters are retained.
