FIRMWARE EDITING
  • m43l
    • Mar 2011
    • 14
    FIRMWARE EDITING
    can you tell me what the program to edit for firmware file?
    - ekstensien PRG
  • HELIO240
    • Jan 2011
    • 137
    Re: FIRMWARE EDITING
    - ekstensien PRG
    for what you wish edit the firmware?It is can be a very dangerous for your system and can cause enjury in your machine.
    The same must be made for by personal authorized in the
    industries and any change for by error they will send a new version for you.
    • m43l
      • Mar 2011
      • 14
      yes, i know the risk,
      but i want to edit the language of machine.
      • Sama
        • May 2010
        • 18
        You want to translate into Indonesian ?.
        You should find firmware with multi-language from factory.
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5015
          Wich model of machine?
          • HELIO240
            • Jan 2011
            • 137
            what the language do you need?l believe that must have a one for your country.
            • teckat
              • 16083
              u mean control panel language
              this is all u can use below/unless u purchased printer in your country
              J Japanese
              E English
              F French
              I Italian
              G German
              S Spanish
              C/T Chinese
              K Korean
              COPIER>DISPLAY>VERSION>LANG-XX.
              Check to make sure that the version of each language module matches the version of the installed system software; otherwise, use the language module built into the system software to start up. The built-in module is not part of the modules that may be selected as the display language; for this reason, you will not be able to make use of the language switch unless you have installed modules
              independently of the system software. If you replace an existing language module with a module of an inappropriate version, ‘E744-0001’ will be indicated when the machine is started up for the first time; to reset the error, install a module of the correct version.
              • m43l
                • Mar 2011
                • 14
                yes , i want to change to indonesian language, do you have source for it?
                • ymmtech
                  • Jun 2009
                  • 190
                  Do you means you want a melayu version ?
                  • Sama
                    • May 2010
                    • 18
                    He come from Surabaya, Indonesia.
                    • m43l
                      • Mar 2011
                      • 14
                      yes, i am from surabaya ,
                      do you have melayu versions?
                      • HELIO240
                        • Jan 2011
                        • 137
                        what model we are talking about ?which manufacturer?
                        • DAG COPIERS & COMPUTERS
                          • Oct 2010
                          • 860
                          This was a very interesting thread, unfortunately it seems to have terminated prematurely by the poster, therefore leaving us all who were keenly following it, in suspense!!!
                          I have noticed an increase in this trend in the forum whereby, some member starts a thread AND when it becomes 'hot',OR a solution has been provided which solved their problem, they EITHER simply back off, OR go quiet, to the dissatisfaction of other members. The best thing to do is to reach a logical conclusion on all threads started, through continued discussion & FEED BACKS so that all members can draw some lessons & inspiration from the thread.
                          TUNEUP COMRADES.
