can you tell me what the program to edit for firmware file?
- ekstensien PRG
for what you wish edit the firmware?It is can be a very dangerous for your system and can cause enjury in your machine.
The same must be made for by personal authorized in the
industries and any change for by error they will send a new version for you.
yes, i know the risk,
but i want to edit the language of machine.
u mean control panel language
this is all u can use below/unless u purchased printer in your country
J Japanese
E English
F French
I Italian
G German
S Spanish
C/T Chinese
K Korean
COPIER>DISPLAY>VERSION>LANG-XX.
Check to make sure that the version of each language module matches the version of the installed system software; otherwise, use the language module built into the system software to start up. The built-in module is not part of the modules that may be selected as the display language; for this reason, you will not be able to make use of the language switch unless you have installed modules
independently of the system software. If you replace an existing language module with a module of an inappropriate version, ‘E744-0001’ will be indicated when the machine is started up for the first time; to reset the error, install a module of the correct version.
This was a very interesting thread, unfortunately it seems to have terminated prematurely by the poster, therefore leaving us all who were keenly following it, in suspense!!!
I have noticed an increase in this trend in the forum whereby, some member starts a thread AND when it becomes 'hot',OR a solution has been provided which solved their problem, they EITHER simply back off, OR go quiet, to the dissatisfaction of other members. The best thing to do is to reach a logical conclusion on all threads started, through continued discussion & FEED BACKS so that all members can draw some lessons & inspiration from the thread.
