Drum middle volume. (iR 5000 series)
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    Hello everyone!
    A curiosity ... Is there a method, a product, a trick to cover the small holes that can form on the surface of the drums of the iR 5000?
  • vigour
    • Aug 2010
    • 1039
    Re: Drum middle volume. (iR 5000 series)
    Clear nail polish or crazy glue has been suggested for small dings and scratches.
    I don't think you can see the arc marks most times.
    make sure to clean/ change your transer/sep within the specified periods.
    It's much cheaper than a drum replacement.
    Transer/sep arcing has been a problem since NP7550
    • Ingranaggio_rotto
      • Oct 2010
      • 275
      "Crazy glue" ? I do not understand? You can translate it in another way?
      Thank you !
      • JustManuals
        • Jan 2006
        • 9838
        Originally posted by Ingranaggio_rotto
        Hello everyone!
        If we told you, we'd have to kill you too.
        • Ingranaggio_rotto
          • Oct 2010
          • 275
          • vigour
            • Aug 2010
            • 1039
            Cyanoacrylate
            Use extreme caution
            • Oze
              Ricoh Fanboy
              • 1663
              The pinholes on the surface of the drum tend to come from the Trans/sep Corona arcing to the drum and damaging it...as Vigour stated.
              Best way to avoid the damage is to either rewire your Primary units OR replace them completely.
              • Ingranaggio_rotto
                • Oct 2010
                • 275
                Thanks for the tips!
