iR2870 Finisher-S1
  • Peter Sim
    • Sep 2008
    • 445
    iR2870 Finisher-S1
    Hai all ,
    Need help.
    When on copier,the stack tray will move down to bottom.
    Without any error code,i exchange another board and check the lower limit sensor,the stack tray still move down to bottom.
    Any suggestion?
    Thank you in advance.
  • Peter Sim
    • Sep 2008
    • 445
    Re: iR2870 Finisher-S1
    Solved the problem,thank you
    • Brian8506
      • 1667
      And the solution was???
      • Peter Sim
        • Sep 2008
        • 445
        It was the paper surface sensor(PI3) level spring missing
        • Simons
          • Jun 2008
          • 490
          that sensor flag on the bottom of the finisher was updated and its a pain to get that spring on!
