Potential control system theories
  • Rachid.Akli
    • Oct 2011
    • 595
    Dear all
    I observed that many CQ issues are posted about mainly printers/copiers above 50 ppm. They could be well understood if we integrate the potential control in the issue analysis. So i just would like to initiate a discution about it.
    Rachid.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    Re: Potential control system theories
    Hi to all
    In a copier apparatus having a photosensitive member such as a drum, good reproductivity and image density results from applying a proper charging potential to the photosensitive substance on the drum. The optimum charging potential for each drum can be predetermined and a code or indicia representative of such optimum potential may be attached or otherwise appended to the drum. This code is read by a suitable sensor which in turn controls the charging potential applied to the drum. but by the way always i turn it off ------PO-CNT. -----OFF -- that make me Win more time.
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
