IR4570 , Print out toner not stick to paper .. ( heater do not feel hot )
  • Copyjaya
    • Oct 2011
    • 59
    Hi all ,
    I found that my IR4570 print out the toner can easily wipe off .. not stick to the paper ..
    i've try to change the other heather unit but still the same .. i guess its not because of the heather unit ..
    PCB ? is it which pcb board ? please help .. **
  • mezerwi
    • Aug 2010
    • 58
    Re: IR4570 , Print out toner not stick to paper .. ( heater do not feel hot )
    loose connection to the heater maybe?
    • Copyjaya
      • Oct 2011
      • 59
      loose connection ? which part do i need to check ? please advise ?
      • Rachid.Akli
        • Oct 2011
        • 595
        Hi to all,
        You've a fixing pressure issue. When replacing the fixing film, take care to adjust the close/open right door system. It's shown in the attachment.
        Rachid.
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5007
          heater do not feel hot??
          Put your feelings on the side and check fix temperature.COPIER>DISPLAY>ANALOG
          • teckat
            • 16083
            to add on----
            • Copyjaya
              • Oct 2011
              • 59
              But .. ive change the other heater unit on it .. still the same . the unit i've used i install it in the other IR4570 it works normal .
              thats why im not suspect the heater unit problem. Any idea on PCB board can effect the heater issue ?
              • Matoku
                • 173
                It can be the dc controller pcb and the power supply too.
                • Rachid.Akli
                  • Oct 2011
                  • 595
                  Dear all
                  Verify the fuser temprature on: Copier>Display>Analog>Fix-C and Fix-E during printing cycle
                  • Copyjaya
                    • Oct 2011
                    • 59
                    i've check the Copier>Display>Analog>Fix-C and Fix-E .. its above 180deg when printing ..
                    but .. when i test print the test pattern No2 ..toner can easily wipe off ..
                    i've change the power board ..is it the DC controller board is on the left side of the back cover ? or the board with the Hard dise ?
                    • Copyjaya
                      • Oct 2011
                      • 59
                      Originally posted by teckat
                      to add on----
                      Hi Teckat .. if not mistaken every time when we need to change the Fuser film we should open the screw mentioned am i correct ?
                      • teckat
                        • 16083
                        NO NO NO
                        u do not touch those screws in the picture/
                        please read the POSTED statement/
                        READ THIS PDF>> iR4570_Fixing Unit.pdf
                        Also....
                        Inspect the latch that releases and applies pressure to the fixing film /make sure it is not bent> causing this mechanism to work erratically (proper and improper pressure when the Main Right side door is closed ).
                        • Copyjaya
                          • Oct 2011
                          • 59
                          woow.. thanks for the PDF Teckat ..
                          • Rachid.Akli
                            • Oct 2011
                            • 595
                            Dear all
                            Since the fixing assembly works well on another machine, i suppose that the fixing pressure adjustment screws are OK.
                            To give you more information about the right door close/ open system, notice that when opening the right door, the fixing film and the pressure roller are separated (for clearing jam purposes) and when closing,they are pressing each other for good fixing purposes. Since the copier displays a correct fixing temprature, then i imagine that power and dc controller pcbs are ok. So, the only remaining parameter is a lack of fixing pressure.
                            Rachid.
                            • Oze
                              Ricoh Fanboy
                              • Jul 2008
                              • 1663
                              THAT is the screw for adjusting the pressure that you NEVER EVER touch
