IR4570 , Print out toner not stick to paper .. ( heater do not feel hot )
  • Matoku
    • 173
    #16
    Re: IR4570 , Print out toner not stick to paper .. ( heater do not feel hot )
    Tha DC Controller PCB is the one which is beside of the Main controller board ( the board with HDD is main controller board )
    This problem some time because of the pressure roller faulty. change it if you touch it too soft.
    • d7guitar
      • Jan 2007
      • 54
      #17
      It could be incorrect toner!
      After all is said and done, More is said than done.
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        #18
        Or aftermarket fixing film.
        I remember having a batch of dodgey Katun films for this model that wouldn't fuse correctly.
        • Copyjaya
          • Oct 2011
          • 59
          #19
          Thanks for the reply ..
          i've try to change to DC controller board ! it works ! now getting better on the print out ..
          at the same time , i've change the new fixing film and change a new drum too .. haha ..
          • Copyjaya
            • Oct 2011
            • 59
            #20
            Now i facing another issue again . do you guys know why the paper sorter unable to sort & catch the paper ? it will fly all over the floor when you print more somethings wrong with the finisher unit ?
            • bineshpaul
              • Jul 2010
              • 43
              #21
              dust may be the problem. clean the finisher area using blower and clean the sensor.RegardsBinesh
              • logonjim
                • 136
                #22
                Check the wire actuator on the right hand side door as this can get bent and cause poor fixing
                • Copyjaya
                  • Oct 2011
                  • 59
                  #23
                  Thanks bineshpaul & Canon.Tech .
                  Do you guys have the offset roller part's number ?
                  • Copyjaya
                    • Oct 2011
                    • 59
                    #24
                    Noted with thanks logonjim ..
                    • Copyjaya
                      • Oct 2011
                      • 59
                      #25
                      Originally posted by Canon.Tech
                      4A3-1121-000 2x ROLLER, OFFSET
                      Many thanks !!!
                      • Copyjaya
                        • Oct 2011
                        • 59
                        #26
                        hi guys ! would like to ask whether the values in the " COPIER>DISPLAY>ANALOG " able to change ?
                        • teckat
                          • 16083
                          #27
                          u can not change that display
                          • zoraldinho
                            teacher-guide-expert-guru
                            • Mar 2008
                            • 5017
                            #28
                            Wich one you won't to change and why??
                            • Matoku
                              • 173
                              #29
                              What is displayed on screen is, what is going on in the copier. nothing to change with it.
